Grundig 32vle7150c Grundig 32vle7150c stuck in standby
Diskutiere Grundig 32vle7150c Grundig 32vle7150c stuck in standby im Forum Grundig TV - Softwareprobleme im Bereich Reparatur von LCD Plasma Fernsehern sowie Beamer - Hersteller: Grundig Typenbezeichnung: 32vle7150c Inverter: Chassi: SX kurze Fehlerbeschreibung (2-3 Worte): Grundig 32vle7150c stuck in...
mrtv
03.09.2015
8
Chassi: SX
kurze Fehlerbeschreibung (2-3 Worte): Grundig 32vle7150c stuck in standby
Hi everyone!
I have a Grundig LCDTV 32vle7150c(se attached label pics) with a suspected firmwarecrash, psu voltages are ok, front-led is on, nothing else happens...
If anyone have a suggestion of suitable firmware it would be greatly appreciated...
Kind Regards
Harry
KimsRTV
Sweden
mrtv
03.09.2015
8
Fixed, I managed to get hold on the firmware, if anyone is interested and in need it´s downbelow .
firmwareSX
BE CAREFUL!
SX chassis comes with various different panels(in my case ..AU55) if you have a tv with the same labels as mine you are ready to go otherwise you have to rename the correct file according to your paneltype.
Copy the "Target" directory on a empty 2 GB usbstick(FAT)
pull out powercord on tv
while pressing P+ on the tv plugin powercord you can release pressing when the upgrade message starts.
Please check you panel type and rename corresponding panel file to Target\BEKO_BIN_FILES\panel\panel.bin
Example for: 32 VLE 8041 S
Panel: LTA320HF05-001 056D32-S22
File PANEL.320SS22.-.F.-.V01.006.00.bin should be renamed to Target\BEKO_BIN_FILES\panel\panel.bin
Then copy Target folder into the root of you USB stick.
IMPORTANT!
USB stick size should be 2 Gb. USB stick should be formated in FAT.
PANEL.320LP22.-.F.-.V01.003.00.bin
PANEL.320LP24.-.F.-.V01.005.00.bin
PANEL.320SS23.-.W.-.V01.004.00_2K.bin
PANEL.370LP29.-.F.-.V01.002.00.bin
PANEL.400SS17.-.F.-.V01.004.00.bin
PANEL.400SS20.-.F.-.V01.003.00.bin
PANEL.420LP34.-.F.-.V01.002.00.bin
PANEL.460SS08.-.F.-.V01.005.00.bin
PANEL.SX.260AU26.-.W.-.V01.003.00_2K.bin
PANEL.SX.260LP15.-.W.-.V01.002.00_2K.bin
PANEL.SX.260LP18.-.W.-.V01.001.00_2K.bin
PANEL.SX.260SS6.-.W.-.V01.002.00_2K.bin
PANEL.SX.260SS7.-.W.-.V01.002.00_2K.bin
PANEL.SX.320AU55.-.F.-.V01.003.00_2K.bin
PANEL.SX.320AU56.-.F.-.V01.003.00_2K.bin
PANEL.SX.320AU58.C.F.-.V01.002.00_2K.bin
PANEL.SX.320LP25.-.F.-.V01.002.00_2K.bin
PANEL.SX.320LP27.-.F.-.V01.001.00.2K.bin
PANEL.SX.320LP28.-.F.-.V01.002.00_2K.bin
PANEL.SX.320LP30.B.F.-.V01.001.00_2K.bin
PANEL.SX.320SS26.-.F.-.V01.002.00_2K.bin
PANEL.SX.320SS28.-.F.-.V01.003.00_2K.bin
PANEL.SX.320SS28.B.F.-.V01.003.00_2K.bin
PANEL.SX.320SS29.B.F.-.V01.002.00_2K.bin
PANEL.SX.320SS31.-.W.-.V01.001.00_2K.bin
PANEL.SX.320SS32.-.F.-.V01.001.00_2K.bin
PANEL.SX.320SS33.B.F.-.V01.001.00_2k.bin
PANEL.SX.320SS33.C.F.-.V01.001.00_2K.bin
PANEL.SX.370LP28.C.F.-.V01.001.00_2K.bin
PANEL.SX.400SS21.-.F.-.V01.003.00.bin
PANEL.SX.400SS21.A.F.-.V01.004.00_2K.bin
PANEL.SX.400SS21.B.F.-.V01.002.00_2K.bin
PANEL.SX.400SS22.-.F.-.V01.002.00_2K.bin
PANEL.SX.400SS23.B.F.-.V01.002.00_2K.bin
PANEL.SX.420LP32.-.F.-.V01.001.00_2K.bin
PANEL.SX.460SS10.-.F.-.V01.001.00_2K.bin
PANEL.SX.460SS13.-.F.-.V01.002.00_2K.bin
PANEL.SX.460SS15.A.F.-.V01.002.00_2K.bin
PANEL.SX.550SS02.-.F.-.V01.003.00.bin
panel_empty.bin
Thema: Grundig 32vle7150c Grundig 32vle7150c stuck in standby
Grundig 43 GUB 8852
grundig 40 vle 6420 bh only logo sometimes and led flash
Grundig TV 43 vle 6621 BP
Problem with my Grundig New York 46s that looks like lots of people had problem with
DVB-T2 auf 40 VLE 5520 BN und 40 VLE 4324 BF
