estemugue
- 15.02.2005
- 7
Hersteller:
Typenbezeichnung:
Hi!
I don't speak german and English very bad but I will try it.
I've flashed my dbox with a lot of images, bluepeer, sporster,,etc but dbox don't run, stops in "loading kernel". I've tried with bootmanager and image with bootloader but the problem continuous. I'm desperate!!!.
Both process are sucesfull but the dbox don't run.
Is a problem of hardware?? please help me.
This is my bootlog:
debug: DDF: Calibrating delay loop... debug: DDF: 67.79 BogoMIPS
debug: BMon V1.0 mID 01
debug: feID dd gtxID 0b
debug: fpID 5a dsID 01-79.38.2d.07.00.00-1e
debug: HWrev X5 SWrev 0.81
debug: B/Ex/Fl(MB) 32/00/08
WATCHDOG reset enabled
dbox2:root> debug:
BOOTP/TFTP bootstrap loader (v0.3)
debug:
debug: Transmitting BOOTP request via broadcast
debug: Given up BOOTP/TFTP boot
boot net failed
Flash-FS bootstrap loader (v1.5)
Found Flash-FS superblock version 3.1
Found file /root/platform/nokia-dbox2/kernel/os in Flash-FS
debug: Got Block #0032
will verify ELF image, start= 0x800000, size= 158824
verify sig: 262
Branching to 0x40000
U-Boot 1.1.4 (Tuxbox) (May 29 2006 - 15:34:06)
CPU: PPC823ZTnnA at 67.200 MHz: 2 kB I-Cache 1 kB D-Cache
*** Warning: CPU Core has Silicon Bugs -- Check the Errata ***
Board: DBOX2, Nokia, BMon V1.0
Watchdog enabled
I2C: ready
DRAM: 32 MB
FLASH: 8 MB
Scanning JFFS2 FS: .. done.
FB: ready
LCD: ready
In: serial
Out: serial
Err: serial
Net: SCC ETHERNET
Options:
1: Console on null
2: Console on ttyS0
3: Console on framebuffer
Select option (1-3), other keys to stop autoboot: 0
### FS (cramfs) loading 'vmlinuz' to 0x100000
### FS load complete: 675625 bytes loaded to 0x100000
Un-Protected 63 sectors
## Booting image at 00100000 ...
Image Name: dbox2
Image Type: PowerPC Linux Kernel Image (gzip compressed)
Data Size: 675561 Bytes = 659.7 kB
Load Address: 00000000
Entry Point: 00000000
Verifying Checksum ... OK
Uncompressing Kernel Image ... OK
Linux version 2.4.32-dbox2 (root@(UNERWÜNSCHTER INHALT, Anm. d. Forenbetreibers)) (gcc version 3.4.4) #20 Mon May 29 15:3
1:12 MSD 2006
On node 0 totalpages: 8192
zone(0): 8192 pages.
zone(1): 0 pages.
zone(2): 0 pages.
Kernel command line: console=ttyS0 root=/dev/mtdblock3 rootfstype=squashfs
Decrementer Frequency = 252000000/60
m8xx_wdt: active wdt found (SWTC: 0xFFFF, SWP: 0x1)
m8xx_wdt: keep-alive trigger installed (PITC: 0x12C0)
Console: colour dummy device 80x25
Calibrating delay loop... 66.96 BogoMIPS
Memory: 30784k available (1140k kernel code, 376k data, 68k init, 0k highmem)
Dentry cache hash table entries: 4096 (order: 3, 32768 bytes)
Inode cache hash table entries: 2048 (order: 2, 16384 bytes)
Mount cache hash table entries: 512 (order: 0, 4096 bytes)
Buffer cache hash table entries: 1024 (order: 0, 4096 bytes)
Page-cache hash table entries: 8192 (order: 3, 32768 bytes)
POSIX conformance testing by UNIFIX
Linux NET4.0 for Linux 2.4
Based upon Swansea University Computer Society NET3.039
Initializing RT netlink socket
Starting kswapd
devfs: v1.12c (2002081 Richard Gooch (<a href="mailto:**********">**********</a>)
devfs: boot_options: 0x1
JFFS2 version 2.2. (NAND) (C) 2001-2003 Red Hat, Inc.
Squashfs 2.2-r2+LZMA (released 2005/09/0 (C) 2002-2005 Phillip Lougher
i2c-core.o: i2c core module version 2.6.1 (20010830)
i2c-dev.o: i2c /dev entries driver module version 2.6.1 (20010830)
CPM UART driver version 0.04
ttyS0 at 0x0280 is on SMC1 using BRGttyS1 at 0x0380 is on SMC2 using BRG2
pty: 256 Unix98 ptys configured
eth0: CPM ENET Version 0.2.dbox2 on SCC2, 00:50:9c:1b:55:23
loop: loaded (max 8 devices)
D-Box 2 flash driver (size->0x800000 mem->0x10000000)
D-Box 2 flash memory: Found 2 x16 devices at 0x0 in 32-bit bank
Intel/Sharp Extended Query Table at 0x0035
cfi_cmdset_0001: Erase suspend on write enabled
Creating 7 MTD partitions on "D-Box 2 flash memory":
0x00000000-0x00020000 : "BR bootloader"
0x00020000-0x00040000 : "FLFS (U-Boot)"
0x00040000-0x00100000 : "boot (Cramfs)"
0x00100000-0x00560000 : "root (Squashfs)"
0x00560000-0x00800000 : "var (JFFS2)"
0x00020000-0x00800000 : "Flash without bootloader"
0x00000000-0x00800000 : "Complete Flash"
Linux video capture interface: v1.00
mice: PS/2 mouse device common for all mice
NET4: Linux TCP/IP 1.0 for NET4.0
IP Protocols: ICMP, UDP, TCP
IP: routing cache hash table of 512 buckets, 4Kbytes
TCP: Hash tables configured (established 2048 bind 4096)
NET4: Unix domain sockets 1.0/SMP for Linux NET4.0.
VFS: Mounted root (squashfs filesystem) readonly.
Mounted devfs on /dev
Freeing unused kernel memory: 68k init
Bad emulation init/1
NIP: 0fed0684 instruction: 4c4802a6 opcode: 13 A: 8 B: 0 C: a code: 153 rc: 0
pte @ 0x fed0684: (0xc1ea40fc)->(0xc1e6ab40)->0x01e0b889
RPN: 01e0b PP: 2 SPS: 1 SH: 0 CI: 0 v: 1
Kernel VA for NIP 0xc1e0b684 pte @ 0xc1e0b684: no pmd
Typenbezeichnung:
Hi!
This is my bootlog:
dbox2:root> debug:
debug:
boot net failed
verify sig: 262
Watchdog enabled
I2C: ready
DRAM: 32 MB
FLASH: 8 MB
FB: ready
LCD: ready
In: serial
Out: serial
Err: serial
Net: SCC ETHERNET
Options:
1: Console on null
2: Console on ttyS0
Image Name: dbox2
1:12 MSD 2006
zone(1): 0 pages.
zone(2): 0 pages.
Starting kswapd
