Grundig 32 VLC 6120 C Twice blue blinks, will not turn on
Diskutiere Grundig 32 VLC 6120 C Twice blue blinks, will not turn on im Forum Reparatur von LCD Plasma Fernsehern sowie Beamer im Bereich Reparaturtips braune Ware - Hersteller: Grundig Typenbezeichnung: 32 VLC 6120 C Inverter: Chassi: kurze Fehlerbeschreibung (2-3 Worte): Twice blue blinks, will not turn...
V
VeikoLaht
10.12.2015
kurze Fehlerbeschreibung (2-3 Worte): Twice blue blinks, will not turn on
Hi,
I am new in this forum and German is not the language I understand well, so maybe English is also acceptable here :)
Concerning this above mentioned Grundig TV, I have understood from your themes and answers, that it can be a problem with firmware, because all capacitors seems to be OK and voltages as well.
Grundig homepage does not support old TV´s with software, so I found this forum.
My e-mail address is **********
With firmware would be good to have a "manual" - how to use it. :)
Best regards
Veiko
RHarbig
RHarbig
03.05.2005
1.369
115
Hello there,
I have sent you a personal message.
greeting
RHarbig
V
VeikoLaht
10.12.2015
Hi,
Thank you, RHarbig, for your files!
I have tried here to update my TV, but it seems there is however something wrong.
First it like made update, it took ca five minutes, and then was black screen and quiet again.
Next time I tried to update it loaded ca 15% and stopped for many hours until I turned it off.
I will try tomorrow again.
RHarbig
RHarbig
03.05.2005
1.369
115
Hello there,
Change also the stick times, do not take too big stick.
greeting
RHarbig
V
VeikoLaht
10.12.2015
Hi,
I tried many USB memory sticks with different sizes, but it did not help - still stuck in the beginning of installation.
But I found solution for my TV from another site where were the same files that you, RHarbig, recommended for me and additionally one .zip file which solved problem with TV. This had also "Target" folder and sub-folders but it was double less in capacity.
Anyway it does not reduce your contribution, RHarbig. :) I got from you idea what exactly to look for.
I noticed, that after installing this last .zip file, TV self wrote "_GRPVR" folder on the USB memory stick.
Of course, for me it is quite amazing, that it was possible to repair TV only with some program. :)
Best regards
Veiko
Thema: Grundig 32 VLC 6120 C Twice blue blinks, will not turn on
Philips 55OLED803/56 Main 714G8465-MOG-B01-005K Not started
Sony KD-55XE8096, lightning strikes
Philips 55OLED903/12 TV blinks one long and 2 short
Grundig Grundig 39 VLE 945 BL The edge LEDs backlight flashed twice and then dark.
TV Grundig 55 VLE 9270 BL - Problem
