grundig 40 vle 6420 bh only logo sometimes and led flash
Diskutiere grundig 40 vle 6420 bh only logo sometimes and led flash im Forum Grundig TV - Softwareprobleme im Bereich Reparatur von LCD Plasma Fernsehern sowie Beamer - hello. last night i found this place and get surprised. wonderfull thank you very much. i have grundig 40 vle 6420 bh when plugged in, tv showed...
pep2k21
12.04.2021
hello.
i have grundig 40 vle 6420 bh when plugged in, tv showed logo sometimes, not all the times, backlight on,
then led flashes blue about 5 times and everything goes off but led light stay blue. (today logo is not showing, only backlight try to start and goes off fast)
no response to remote except if i press channel +/- then blinks again, tries to start. once or twice, then led blue light go a bit soft blue and no response.
tried firmware from here, found 3 of them,
KYGRMR.-.-.-.-.V07.034.36,
KYGRMR.-.-.-.-.V07.034.39, and
KYGRMR.-.-.-.-.V07.052.00
for about half a second i could see the software upgrade process at 1% was starting on screen, then went off again and led blue flashing for about 1 or 2 min.after this blue led stay with no flash. same than at begin.
i read a few coments about similar errors ending with a main board replacement. i have a programmer is it a bad idea to try to program spi or nand?
it may be power board?
what do you think?
thank you very much
9.197
651
You need a new motherboard. No panel data is included in the software, so you can not describe the NAND.
LG Thomas
pep2k21
12.04.2021
understood. ordering new board then. thanks a lot :)
Thema: grundig 40 vle 6420 bh only logo sometimes and led flash
TV Grundig 55 VLE 9270 BL - Problem
Grundig Grundig 39 VLE 945 BL The edge LEDs backlight flashed twice and then dark.
Grundig 32 VLE 4720 BN kein Bild nach Update
Grundig 55 GUB 8765 blue led blinking
Grundig TV 43 vle 6621 BP
