Grundig 46 VLE 7139 BR Software Update
Diskutiere Grundig 46 VLE 7139 BR Software Update im Forum Grundig TV - Softwareprobleme im Bereich Reparatur von LCD Plasma Fernsehern sowie Beamer - Hi, I need a little help with software update for this model: Grundig 46 VLE 7139 BR Chassis: TP Software: TPGRMR.-.-.-.-.V02.003.00 Bootloader...
daniel_82
29.12.2018
Hi,
Chassis: TP
Bootloader: BOOT.TP.-.-.-.-.V01.008.00
Panel E2 Ver.: 460SS13.A.F.-.V01.009.00
I tried to make a software update in the beginning from internet, but always i got an error saying that update failed due to an error.
Next thing i followed this: https://forum.iwenzo.de/grundig-service-anleitung-blinkcode--t61847.html and tried to update with this SW: TPGRMR.-.-.-.-.V05.013.00
When i entered service menu to update the "Boot Code Configuration" it says "Fail", the reason for that is the "BOOTLOADER" version is to old for TPGRMR.-.-.-.-.V05.013.00 with BOOTLOADER: BOOT.TP-.-.-.-.V01.012.00 and not allowed the update to perform.
Is that another way to perform the update without the ISP tool?
I belive that i need to make all the updates (with all version starting with TPGRMR-V02.003 to TPGRMR-V05.013)
Can you help with this?
Thank you and best regards everyone !!!
9.197
651
daniel_82
29.12.2018
Hi thommyX,
Thank you for your support, i manage to perform all the updates.
Just followed the guide and everything is ok, current SW: TPGRMR.-.-.-.-.V05.013.00
Best regards Daniel
9.197
651
Thank you and thank you for the feedback.
LG Thomas
Thema: Grundig 46 VLE 7139 BR Software Update
Philips 55OLED803/56 Main 714G8465-MOG-B01-005K Not started
Sony KD-55XE8096, lightning strikes
40 VLE 6421 BL, no picture after software upgrade
TV Grundig 55 VLE 9270 BL - Problem
nur kurz beim Booten von Grundig 32 VLE 6325 BG vom Grundig Screen
