Philips 55PFL6158S/12 Ams driver setting
Diskutiere Philips 55PFL6158S/12 Ams driver setting im Forum Reparatur von LCD Plasma Fernsehern sowie Beamer im Bereich Reparaturtips braune Ware - Hersteller: Philips Typenbezeichnung: 55PFL6158S/12 Inverter: Chassi: QFU1.2E LA kurze Fehlerbeschreibung (2-3 Worte): Ams driver setting...
mrtv
03.09.2015
8
Hersteller: Philips
Chassi: QFU1.2E LA
Hi everyone!
I wonder if there´s a QFU1.2E chassis guru out there?
After a mainboard change from p/n 310432881641 to p/n 310432880861 plus set all optioncodes and settings and upgraded the latest firmware everything works fine except I can´t get the Ambilight working, all fuses are checked OK, voltages ok and cables undamaged.
I believe its a settingsproblem(se attached pdf) and looking for the UPG-file to set the drivertype in NVM correct which i think is set to TI (instead of AMS).
anyone who would like to share the AMS settingfile?
Kind Regards
Harry
KimsRTV
  • ticket_4031434_1_2_D982298.pdf
POL UK
POL UK
07.06.2016
132
You need to upgrage after Main PCB change also AMS driver.
mrtv
03.09.2015
8
Hi Tomek and thanks for the tip!
The main problem I have is to get the driver+setting upgrade files, can´t be found anywere..
Philips is not very helpful which is very weird they refuse to share them.. They sent me
the pdf-file of a servicebulletin (but not the files that should have been attached with it)..
Regards
Harry
KimsRTV
POL UK
POL UK
07.06.2016
132
I'm on Ski Holliday till Sunday after Sunday I can send you missing files.
mrtv
03.09.2015
8
:-) Many many many many Thanks !!!!!!!!!!!!!!
To find those files is more difficult than finding water in Sahara..
Kind Regards
Harry
KimsRTV
Thema: Philips 55PFL6158S/12 Ams driver setting
Philips 55OLED803/56 Main 714G8465-MOG-B01-005K Not started
Sony KD-55XE8096, lightning strikes
Philips 55OLED903/12 TV blinks one long and 2 short
grundig 40 vle 6420 bh only logo sometimes and led flash
Hanseatic Side by side refrigerator Cools down and then heats up
