servicemode für Sony KV-32LS60E
Diskutiere servicemode für Sony KV-32LS60E im Forum Reparatur Fernseher und TV Geräte im Bereich Reparaturtips braune Ware - Hersteller: Sony Typenbezeichnung: KV-32LS60E Chassi...
O
ohmxxl
16.02.2005
279
Hersteller: Sony
Dein Wissensstand: Profi (Meister, Diploming., DR)
Hallöchen,
Kann mir evtl.jemand sagen wie ich in den Servicemode von diesem Gerät komme?
guß ohmxxl
EM2-Gott
4-1. Electrical Adjustments
Service adjustments to this model can be performed using the
supplied remote Commander RM-934.
SECTION 4 CIRCUIT ADJUSTMENTS
1. Press the VCR/TV/DVD button until the
TV LED lights.
2. Press and hold the yellow button for
approx. 5 seconds until the TV LED
flashes quickly.
3. Press 99999. All three LED’s should light.
The remote commander is now set to Service Mode.
4. To return the remote commander to normal operation mode
repeat steps 1. and 2. then press 00000. All three LED’s
should light.
The remote commander is now set to normal mode.
Programming the Remote Commander for
Operation in Service Mode
Setting the TV into Service Mode
1. Program the remote commander for operation in Service
Mode as described above.
2. Turn on the TV main power switch.
3. Press the video standby button on the remote
commander twice.
‘TT ’ will appear in the upper right corner of the screen.
Other status information will also be displayed.
4. Press ‘MENU’ on the remote commander to obtain the
following menu on the screen.
5. Move to the corresponding adjustment item using the
up or down arrow buttons on the Remote Commander.
6. Press the right arrow button to enter into the required menu item.
7. Press the ‘Menu’ button on the Remote Commander to quit the
Service Mode when all adjustments have been completed.
Note :
· After carrying out the service adjustments, to prevent the
customer accessing the ‘Service Menu’ switch the TV set
OFF and then ON.
O
ohmxxl
16.02.2005
279
Servicemode Sony
hallöchen nochmal,
danke für den servicemode, ist aber leider für nicht möglich mit unser Orginalfernbedienung da dieses Gerät nicht mit mit RM 934 betrieben wir sondern mit der RM 932.Schade oder gibt es noch eine andere möglichkeit
EM2-Gott
HAllo!
Naja, es gibt noch die Sony Service-FB.
Aber die wirst du ja nicht haben.... Eine andere Möglichkeit kenne ich beim AE6B-Chassis leider nicht.
O
ohmxxl
16.02.2005
279
Sony Code
Danke für die nachricht, da hast du recht die habe ich leider nicht, ist aber auch kein problem da ich sie mir morgen von einem Kollegen ausleihen werden.Besten Dank
ohmxxl
Thema: servicemode für Sony KV-32LS60E
Sony KDL-75W855C /FWL-75W855C 6x blinken
Sony 55S8005C Emmc defekt
Sony DCR-TRV8E menu scroll wheel not working Sony DCR-TRV8E
Sony KD-75XD8505 Der Fehler in den Bildern kommen und gehen wieder von alleine.
sony ta-av501r war seit 3 Jahren nicht mehr in Betrieb. Lässt sich nicht mehr einschalten.
