- To correct mismatch of polish language. - To fix the virgin DVD-RW (record title cannot be playback without open close the tray). - To fix the problem of the video title cannot be played back from a DVD-RW after make compatible. - To fix the Naviclick timer recording problem by filter out the "/" character and replace by the character ' - ' at timer name else the recording to HDD cannot start up. - To fix incorrect rental count decrease for Divx files. - To fix incorrect rental count info in the preview window. - No color in secam after a smart record export from HDD to DVD rec. - Implement 10 languages for the OSD menu which include Czech, Hungarian & Russian. - To fix the bug of the digital copy stall problem. - To fix the bug of wrong disc space check after erasing a DVD+RW disc before copying a video title from HDD to a DVD+RW. - To fix the bug - With a DVD+R disc loaded, the copy to disc button is grey out. Hence copying of a video title from HDD to DVD+R is not possible
Ich habe dir die aktuelle Software hier hochgeladen (bitte vorher den Softwarestand prüfen)
