Wie zu Sony Service Menü
Diskutiere Wie zu Sony Service Menü im Forum Reparatur Fernseher und TV Geräte im Bereich Reparaturtips braune Ware - Hersteller: Sony Typenbezeichnung: KV-C2971D, KV-C2961D, KV32LS60E, KV28LS60E Chassi...
point
29.09.2005
Hersteller: Sony
Schaltbild vorhanden: Ja
Weiss jemand?
haben die Geräte KV-C2971D, KV-C2961D, KV32LS60E, KV28LSE
ein Service Menü? wenn ja wie werden diese aufgerufen.
Gibt es für diese Menüs Anleitung?
Gruss
point
point
29.09.2005
mit kv 32ls60e hat sich erledigt
Service adjustments to this model can be performed using the
supplied remote Commander RM-932.
1. Turn on the main power switch of the TV set.
2. Press the VCR/TV/DVD button until the
TV LED lights.
3. Press and hold the yellow button for
approx. 5 seconds until the TV LED
flashes quickly.
4. Press 99999.(schnell) All three LED’s should light.
The remote commander is now set to Service Mode.
5. Press ‘VIDEO’ ‘VIDEO’ > ‘MENU’ on the Remote
Commander.
6. Using the Remote Commander, Scroll to the ‘Error Menu’
item using the down arrow key, then press the right arrow
key.
7. The following table will be displayed indicating the error
count.
8. To return the remote commander to normal operation mode
repeat steps 1. and 2. then press 00000. All three LED’s
should light.
The remote commander is now set to normal mode.
Programming the Remote Commander for
Operation in Service Mode
Setting the TV into Service Mode
1. Program the remote commander for operation in Service
Mode as described above.
2. Turn on the TV main power switch.
3. Press the video standby button on the remote
commander twice.
‘TT ’ will appear in the upper right corner of the screen.
Other status information will also be displayed.
4. Press ‘MENU’ on the remote commander to obtain the
following menu on the screen.
5. Move to the corresponding adjustment item using the
up or down arrow buttons on the Remote Commander.
6. Press the right arrow button to enter into the required menu item.
7. Press the ‘Menu’ button on the Remote Commander to quit the
Service Mode when all adjustments have been completed.
Note :
· After carrying out the service adjustments, to prevent the
customer accessing the ‘Service Menu’ switch the TV set
OFF and then ON.
Thema: Wie zu Sony Service Menü
LG 70LB650V kein Menü - Fehlermeldung - wie Factory Reset über S-Menü?
Sony KDL-40Z5800 Bildschirm bleibt schwarz
Grundig 40VLE6140C Komme nicht ins Service-Menü und Bild steht auf dem Kopf
Sharp LC43XUF8772ES Bootloop
IGNIS ADL 350 Heizt nicht
