debug: DDF: Calibrating delay loop... debug: DDF: 67.79 BogoMIPS
debug: BMon V1.0 mID 01
debug: feID 7a gtxID 0b
debug: fpID 5a dsID 01-ac.c4.18.07.00.00-7f
debug: HWrev X5 SWrev 0.81
debug: B/Ex/Fl(MB) 32/00/08
WATCHDOG reset enabled
dbox2:root> debug:
bootp /TFTP bootstrap loader (v0.3)
debug:
debug: Transmitting BOOTP request via broadcast
debug: Given up BOOTP/TFTP boot
boot net failed
Flash -FS bootstrap loader (v1.5)
Found Flash-FS superblock version 3.1
Found file /root/platform/nokia-dbox2/kernel/os in Flash-FS
debug: Got Block #0036
will verify ELF Image , start= 0x800000, size= 162920
verify SIG : 262
Branching to 0x40000
u-boot 1.2.0 (Tuxbox) (Sep 7 2007 - 22:14:25)
CPU: PPC823ZTnnA at 67.200 MHz: 2 kB I-Cache 1 kB D-Cache
*** Warning: CPU Core has Silicon Bugs -- Check the Errata ***
Board: DBOX2, Nokia, BMon V1.0
Watchdog enabled
I2C: ready
DRAM: 32 MB
FLASH: 8 MB
Scanning JFFS2 FS: ........ done.
FB: ready
LCD: ready
In: serial
Out: serial
Err: serial
Net: SCC ETHERNET
Options:
1: Console on null
2: Console on ttyS0
3: Console on framebuffer
Select option (1-3), other keys to stop autoboot: 0
### FS (squashfs) loading 'vmlinuz' to 0x100000
### FS load complete: 694086 bytes loaded to 0x100000
............................................................... done
Un-Protected 63 sectors
## Booting image at 00100000 ...
Image Name: dbox2
Image Type: PowerPC Linux Kernel Image (gzip compressed)
Data Size: 694022 Bytes = 677.8 kB
Load Address: 00000000
Entry Point: 00000000
Verifying Checksum ... OK
Uncompressing Kernel Image ... OK
Linux version 2.4.34-dbox2 (md-team@mdteamlinux) (gcc version 3.4.4) #4 Fr Sep 7
22:13:18 CEST 2007
On node 0 totalpages: 8192
zone(0): 8192 pages.
zone(1): 0 pages.
zone(2): 0 pages.
Kernel command line: console=ttyS0 root=/dev/mtdblock1 rootfstype=squashfs
Decrementer Frequency = 252000000/60
m8xx_wdt: active wdt found (SWTC: 0xFFFF, SWP: 0x1)
m8xx_wdt: keep-alive trigger installed (PITC: 0x12C0)
Console: colour dummy device 80x25
Calibrating delay loop... 66.96 BogoMIPS
Memory: 30780k available (1180k kernel code, 348k data, 60k init, 0k highmem)
Dentry Cache hash table entries: 4096 (order: 3, 32768 bytes)
Inode cache hash table entries: 2048 (order: 2, 16384 bytes)
Mount cache hash table entries: 512 (order: 0, 4096 bytes)
Buffer cache hash table entries: 1024 (order: 0, 4096 bytes)
Page-cache hash table entries: 8192 (order: 3, 32768 bytes)
POSIX conformance testing by UNIFIX
Linux NET4.0 for Linux 2.4
Based upon Swansea University Computer Society NET3.039
Initializing RT netlink socket
Starting kswapd
devfs: v1.12c (20020818) Richard Gooch (rgooch@atnf.csiro.au)
devfs: boot_options: 0x1
JFFS2 version 2.2. (NAND) (C) 2001-2003 Red Hat, Inc.
squashfs: version 3.0 (2006/03/15) Phillip Lougher
i2c-core.o: i2c core module version 2.6.1 (20010830)
i2c-dev.o: i2c /dev entries driver module version 2.6.1 (20010830)
CPM UART driver version 0.04
ttyS0 at 0x0280 is on SMC1 using BRGttyS1 at 0x0380 is on SMC2 using BRG2
pty: 256 Unix98 ptys configured
eth0: CPM ENET Version 0.2.dbox2 on SCC2, 00:50:9c:1e:5f:6f
loop: loaded (max 8 devices)
D-Box 2 flash driver (size->0x800000 mem->0x10000000)
D-Box 2 flash memory: Found 2 x16 devices at 0x0 in 32-bit bank
Intel/Sharp Extended Query Table at 0x0035
cfi_cmdset_0001: Erase suspend on write enabled
Creating 6 MTD partitions on "D-Box 2 flash memory":
0x00000000-0x00020000 : "BR bootloader"
0x00020000-0x003e0000 : "root (SquashFS)"
0x003e0000-0x007e0000 : "var (JFFS2)"
0x007e0000-0x00800000 : "FLFS (U-Boot)"
0x00020000-0x00800000 : "Flash without bootloader"
0x00000000-0x00800000 : "Complete Flash"
Linux video capture interface: v1.00
mice: PS/2 mouse device common for all mice
NET4: Linux TCP/IP 1.0 for NET4.0
IP Protocols: ICMP, UDP, TCP
IP: routing cache hash table of 512 buckets, 4Kbytes
TCP: Hash tables configured (established 2048 bind 4096)
NET4: Unix domain sockets 1.0/SMP for Linux NET4.0.
VFS: Mounted root (squashfs filesystem) readonly.
Mounted devfs on /dev
Freeing unused kernel memory: 60k init
Starting pid 10, console /dev/console: '/etc/init.d/rcS'lti-call
event: $Id: event.c,v 1.12 2003/09/30 05:45:38 obi Exp $
[i2c-8xx]: mpc 8xx i2c init
[i2c-8xx]: adapter: 0
Detected STB:
Vendor: Nokia
Model: D-BOX2
$Id: cam.c,v 1.30 2004/01/10 16:36:34 alexw Exp $
$Id: avia_napi.c,v 1.18 2003/11/24 09:53:01 obi Exp $
DVB: registering new adapter (C-Cube AViA GTX/eNX with AViA 500/600).
dvb_i2c_bridge: enabled DVB i2c bridge to PowerPC 8xx I2C adapter
$Id: cam_napi.c,v 1.8 2003/09/30 05:45:34 obi Exp $
avia_av: $Id: avia_av_core.c,v 1.99 2006/01/08 21:36:22 carjay Exp $
avia_av_core: Starting avia_av_wdt thread.
avia_av_event: $Id: avia_av_event.c,v 1.11 2003/10/26 16:32:51 obi Exp $
avia_av_proc: $Id: avia_av_proc.c,v 1.15 2007/07/29 18:14:12 papst Exp $
avia_gt_core: $Id: avia_gt_core.c,v 1.48 2004/12/20 01:01:22 carjay Exp $
avia_gt_core: autodetecting chip type... GTX
avia_gt_gtx: $Id: avia_gt_gtx.c,v 1.24 2003/09/30 05:45:35 obi Exp $
avia_gt_accel: $Id: avia_gt_accel.c,v 1.19 2003/09/30 05:45:35 obi Exp $
avia_gt_dmx: $Id: avia_gt_dmx.c,v 1.210 2004/06/26 16:08:15 carjay Exp $
avia_gt_core: masking unhandled irq reg 1 bit 11
avia_gt_core: masking unhandled irq reg 1 bit 13
avia_gt_ucode: loaded ucode v0014
avia_gt_ucode: ucode section filters disabled.
avia_gt_dmx: warning, misaligned queue 0 (is 0xFD200, size 65536), aligning...
avia_gt_core: masking unhandled irq reg 0 bit 6
avia_gt_gv: $Id: avia_gt_gv.c,v 1.39 2004/08/28 16:44:56 carjay Exp $
avia_gt_gv: set_input_size (width=720, height=576)
avia_gt_pcm: $Id: avia_gt_pcm.c,v 1.29 2004/01/29 19:38:20 zwen Exp $
avia_gt_pcm_set_rate(44100)
avia_gt_capture: $Id: avia_gt_capture.c,v 1.32 2003/09/30 05:45:35 obi Exp $
avia_gt_pig: $Id: avia_gt_pig.c,v 1.40 2003/09/30 05:45:35 obi Exp $
avia_gt_vbi: $Id: avia_gt_vbi.c,v 1.26 2003/08/01 17:31:22 obi Exp $
avia_gt_core: Loaded AViA eNX /GTX driver
avia_gt_fb: $Id: avia_gt_fb_core.c,v 1.54 2004/03/17 18:42:18 zwen Exp $
avia_gt_gv: set_input_mode (mode=2)
Console: switching to colour frame buffer device 82x32
avia_gt_fb: fb0: AViA eNX/GTX Framebuffer frame buffer device
lcd.o: init lcd driver module
lcd.o: found KS0713/SED153X lcd interface
avia_gt_lirc: $Id: avia_gt_lirc.c,v 1.14 2003/09/30 05:45:35 obi Exp $
avia_gt_ir: $Id: avia_gt_ir.c,v 1.30 2003/09/30 05:45:35 obi Exp $
avia_oss: $Id: avia_gt_oss.c,v 1.26 2004/05/31 22:56:02 carjay Exp $
avia_gt_v4l2: $Id: avia_gt_v4l2.c,v 1.12 2003/09/30 04:54:03 obi Exp $
DVB: VES1820(0): pwm=0x48
DVB: registering frontend 0:0 (VES1820 based DVB-C frontend)...
avia_av_napi.c: $Id: avia_av_napi.c,v 1.33 2004/03/11 15:30:27 derget Exp $
avia_gt_napi: $Id: avia_gt_napi.c,v 1.203 2005/01/05 05:49:56 carjay Exp $
Starting pid 113, console /dev/console: '/etc/init.d/start'
Please press Enter to activate this console. Thu Jan 1 01:00:00 CET 1970
mv: unable to rename `/lib/tuxbox/plugins/mdextra.cfg': No such file or director
y
cdkVcInfo $Id: cdkVcInfo.c,v 1.0 2002/09/26 20:48:26 alexW Exp $
[CBasicClient] connect failed.
/tmp/sectionsd.sock: No such file or directory
$Id: sectionsd.cpp,v 1.247 2007/08/08 22:17:06 dbt Exp $
[sectionsd] Caching max 5000 events
[sectionsd] Caching 14 days
[sectionsd] Caching 6 hours Extended Text
[sectionsd] Events are old 60min after their end time
/var/tuxbox/config/zapit/epgfilter.xml: No such file or directory
/var/tuxbox/config/mybouquets.xml: No such file or directory
$Id: zapit.cpp,v 1.402 2007/07/22 14:36:42 dbluelle Exp $
[frontend] uncommitted_switch_mode 0
avia_gt_core: masking unhandled irq reg 0 bit 7
/tmp/currentservices.xml: No such file or directory
$Id: controld.cpp,v 1.127 2007/07/01 08:40:13 dbluelle Exp $
[controld] Boxtype detected: (1, Nokia D-BOX2)
[controld]: ROUTEVIDEO v1 = 5 a1 = 1 v2 = 1 a2 = 1 v3 = 0 a3 = 1 fblk=1
[yhttpd] Webserver nhttpd/3.1.3 (yhttpd_core/1.2.0)
[LCDFONT] initializing core...
[LCDFONT] adding font /share/fonts/micron.ttf...OK (Micron/Regular)
[LCDFONT] adding font /share/fonts/micron_bold.ttf...OK (Micron/Bold)
[LCDFONT] adding font /share/fonts/pakenham.ttf...OK (Pakenham/Regular)
[LCDFONT] Intializing font cache...
[yhttpd] Webserver starting...
rm: cannot remove `/var/etc/.sectionsd': No such file or directory
01.01.1970 00:00:12 camd3: BOXTYPE: dbox2
01.01.1970 00:00:12 camd3: LOG: 6
01.01.1970 00:00:12 camd3: UDP_PORT: 8899
01.01.1970 00:00:12 camd3: original slot AU off
01.01.1970 00:00:12 camd3: HTTP_PORT: 9080
01.01.1970 00:00:12 camd3: LOG_HOST: 127.0.0.1:514
01.01.1970 00:00:12 camd3: DNS_CACHE: 60 sec
01.01.1970 00:00:13 camd3: SOCKET: /tmp/camd.sock01
01.01.1970 00:00:13 camd3: KEYS: /var/keys/camd3.keys
01.01.1970 00:00:13 camd3: SERVERS: /var/keys/camd3.servers
01.01.1970 00:00:13 camd3: USERS: /var/keys/camd3.users
01.01.1970 00:00:13 camd3: MAP_LIST: /var/keys/camd3.map
01.01.1970 00:00:13 camd3: IGNORE_LIST: /var/keys/camd3.ignore
01.01.1970 00:00:13 camd3: ECM_INFO: /tmp/ecm.info
01.01.1970 00:00:13 camd3: /var/keys/camd3.map No such file or directory
01.01.1970 00:00:13 camd3: /var/keys/camd3.ignore No such file or directory
01.01.1970 00:00:13 camd3: Slot /dev/tts/1: (carddetect=password1) initialisiere
01.01.1970 00:00:14 camd3: Slot /dev/tts/1: Warnung: IO-Fehler!
01.01.1970 00:00:14 camd3: UserDB(add): USER=benutzer1 PASS=password2 FROM=any S
ERVICES=all
01.01.1970 00:00:14 camd3: original slot: CAID=1722
01.01.1970 00:00:14 camd3: UserDB(add): USER=benutzer110 PASS=password10 FROM=an
y SERVICES=1702:000000:0008,1722:000000:0008,
01.01.1970 00:00:14 camd3: UserDB(update): USER=benutzer110 PASS=password10 FROM
=any SERVICES=1702:000000:0008,1722:000000:0008,
01.01.1970 00:00:15 camd3: KeyDB: started
[LCDFONT] FTC_Face_Requester (Micron/Regular)
01.01.1970 00:00:15 camd3: HTTP: started on port 9080
01.01.1970 00:00:15 camd3: camd v3.889g - erfolgreich gestartet
Neutrino : /lib/libpng12.so.0: no version information available (required by neut
rino)
[neutrino] frameBuffer Instance created
812k video mem
[neutrino] enable flash
[neutrino] Software update enabled
rdate: de.pool.ntp.org: Host name lookup failure
[LCDFONT] FTC_Face_Requester (Micron/Bold)
[lcdd] time-skin not found -> using default...
[lcdd] weekday-skin not found -> using default...
[lcdd] date-skin not found -> using default...
[lcdd] month-skin not found -> using default...
[LCDFONT] adding font /share/fonts/12.pcf.gz...OK (Fix12/Regular)
[LCDFONT] adding font /share/fonts/14B.pcf.gz...OK (Fix14/Bold)
[LCDFONT] adding font /share/fonts/15B.pcf.gz...OK (Fix15/Bold)
[LCDFONT] FTC_Face_Requester (Fix15/Bold)
[LCDFONT] FTC_Face_Requester (Fix14/Bold)
/dev/input/event1: No such file or directory
[neutrino] menue setup
loading locales: scandir: No such file or directory
[neutrino] registering as event client
[neutrino] initialized everything
zap failed!
