alex.dan
Hersteller: sagem
Typenbezeichnung:
Vorhandene Messgeräte: Keine
hallo wenn ich meine dbox an das vernseher anschließe kommt kein signal so ob die ganzen anschlusse hinten nicht funktionieren.am lcd display wird alles wie gewohnt angezeigt.was könnte kaputt sein
das log sieht so aus
Starting kswapd
devfs: v1.12c (2002081 Richard Gooch (<a href="mailto:**********">**********</a>)
devfs: boot_options: 0x1
JFFS2 version 2.2. (NAND) (C) 2001-2003 Red Hat, Inc.
squashfs: version 3.0 (2006/03/15) Phillip Lougher
i2c-core.o: i2c core module version 2.6.1 (20010830)
i2c-dev.o: i2c /dev entries driver module version 2.6.1 (20010830)
CPM UART driver version 0.04
ttyS0 at 0x0280 is on SMC1 using BRGttyS1 at 0x0380 is on SMC2 using BRG2
pty: 256 Unix98 ptys configured
eth0: CPM ENET Version 0.2.dbox2 on SCC2, 00:50:9c:3b:35:3e
loop: loaded (max 8 devices)
D-Box 2 flash driver (size->0x800000 mem->0x10000000)
D-Box 2 flash memory: Found 1 x16 devices at 0x0 in 16-bit bank
Intel/Sharp Extended Query Table at 0x0031
Using buffer write method
cfi_cmdset_0001: Erase suspend on write enabled
Creating 6 MTD partitions on "D-Box 2 flash memory":
0x00000000-0x00020000 : "BR bootloader"
0x00020000-0x00680000 : "root (squashfs)"
0x00680000-0x007e0000 : "var (jffs2)"
0x007e0000-0x00800000 : "flfs (u-boot)"
0x00020000-0x00800000 : "Flash without bootloader"
0x00000000-0x00800000 : "Complete Flash"
Linux video capture interface: v1.00
mice: PS/2 mouse device common for all mice
NET4: Linux TCP/IP 1.0 for NET4.0
IP Protocols: ICMP, UDP, TCP, IGMP
IP: routing cache hash table of 512 buckets, 4Kbytes
TCP: Hash tables configured (established 2048 bind 4096)
NET4: Unix domain sockets 1.0/SMP for Linux NET4.0.
VFS: Mounted root (squashfs filesystem) readonly.
Mounted devfs on /dev
Freeing unused kernel memory: 60k init
init started: BusyBox v1.2.1 (2007.03.17-16:04+0000) multi-call event: $Id: eve
nt.c,v 1.12 2003/09/30 05:45:38 obi Exp $
[i2c-8xx]: mpc 8xx i2c init
[i2c-8xx]: adapter: 0
Oops: kernel access of bad area, sig: 11
NIP: C00B8F7C XER: 00000000 LR: C388E60C SP: C1C9FE30 REGS: c1c9fd80 TRAP: 0300
Not tainted
MSR: 00009032 EE: 1 PR: 0 FP: 0 ME: 1 IR/DR: 11
DAR: 00000024, DSISR: C0000000
TASK = c1c9e000[24] 'insmod' Last syscall: 128
last math 00000000 last altivec 00000000
GPR00: C388E60C C1C9FE30 C1C9E000 C38907DC C38907BA 00000007 0000001B C1C9E03C
GPR08: 00000000 00000004 0000003F C00B8F64 24008042 10076964 00000001 10050000
GPR16: 10070000 00000001 1007E430 1007E170 00009032 C1C9FEA0 C1BCD000 1008EAC8
GPR24: C1C7F2A0 00000003 C3892000 C01485C8 C3890000 00000007 00000000 00000000
Call backtrace:
C388F3D8 C388E60C C388F9F8 C0010FF8 C000285C 10022980 10003D2C
10003DA8 0FEB80DC 00000000
Segmentation fault
i2c-core.o: driver saa7126 registered.
i2c-core.o: client [saa7126] registered to adapter [PowerPC 8xx I2C adapter](pos
. 1).
Detected STB:
Vendor: Sagem
Model: D-BOX2
$Id: cam.c,v 1.30 2004/01/10 16:36:34 alexw Exp $
cam: no firmware file found
$Id: avia_napi.c,v 1.18 2003/11/24 09:53:01 obi Exp $
DVB: registering new adapter (C-Cube AViA GTX/eNX with AViA 500/600).
i2c-core.o: driver DVB I2C bridge registered.
i2c-core.o: client [DVB I2C bridge] registered to adapter [PowerPC 8xx I2C adapt
er](pos. 2).
dvb_i2c_bridge: enabled DVB i2c bridge to PowerPC 8xx I2C adapter
$Id: cam_napi.c,v 1.8 2003/09/30 05:45:34 obi Exp $
Thu Jan 1 01:00:00 CET 1970
avia_av: $Id: avia_av_core.c,v 1.99 2006/01/08 21:36:22 carjay Exp $
avia_av: AVIA500 sptsfix is off
avia_av_core.c: avia_av_firmware_read: Unable to load '/var/tuxbox/ucodes/avia60
0.ux'.
avia_av: microcode not found, setting up dummy
avia_av_proc: $Id: avia_av_proc.c,v 1.14 2004/01/21 20:02:29 carjay Exp $
avia_gt_core: $Id: avia_gt_core.c,v 1.48 2004/12/20 01:01:22 carjay Exp $
avia_gt_core: autodetecting chip type... eNX
avia_gt_enx: $Id: avia_gt_enx.c,v 1.21 2003/09/30 05:45:35 obi Exp $
avia_gt_accel: $Id: avia_gt_accel.c,v 1.19 2003/09/30 05:45:35 obi Exp $
avia_gt_dmx: $Id: avia_gt_dmx.c,v 1.210 2004/06/26 16:08:15 carjay Exp $
avia_gt_ucode: loaded ucode v0014
avia_gt_ucode: ucode section filters enabled.
avia_gt_dmx: warning, misaligned queue 0 (is 0xFD200, size 65536), aligning...
avia_gt_gv: $Id: avia_gt_gv.c,v 1.39 2004/08/28 16:44:56 carjay Exp $
avia_gt_gv: set_input_size (width=720, height=576)
avia_gt_pcm: $Id: avia_gt_pcm.c,v 1.29 2004/01/29 19:38:20 zwen Exp $
avia_gt_pcm_set_rate(44100)
avia_gt_capture: $Id: avia_gt_capture.c,v 1.32 2003/09/30 05:45:35 obi Exp $
avia_gt_pig: $Id: avia_gt_pig.c,v 1.40 2003/09/30 05:45:35 obi Exp $
avia_gt_vbi: $Id: avia_gt_vbi.c,v 1.26 2003/08/01 17:31:22 obi Exp $
avia_gt_core: Loaded AViA eNX/GTX driver
avia_gt_fb: $Id: avia_gt_fb_core.c,v 1.54 2004/03/17 18:42:18 zwen Exp $
avia_gt_gv: set_input_mode (mode=2)
Console: switching to colour frame buffer device 82x32
avia_gt_fb: fb0: AViA eNX/GTX Framebuffer frame buffer device
avia_av_core: Starting avia_gt_wdt thread.
lcd.o: init lcd driver module
lcd.o: found KS0713/SED153X lcd interface
avia_gt_lirc: $Id: avia_gt_lirc.c,v 1.14 2003/09/30 05:45:35 obi Exp $
avia_gt_ir: $Id: avia_gt_ir.c,v 1.30 2003/09/30 05:45:35 obi Exp $
avia_oss: $Id: avia_gt_oss.c,v 1.26 2004/05/31 22:56:02 carjay Exp $
avia_gt_v4l2: $Id: avia_gt_v4l2.c,v 1.12 2003/09/30 04:54:03 obi Exp $
DVB: registering frontend 0:0 (Atmel AT76C651A with TUA6010XS)...
avia_av_napi.c: $Id: avia_av_napi.c,v 1.33 2004/03/11 15:30:27 derget Exp $
avia_gt_napi: $Id: avia_gt_napi.c,v 1.203 2005/01/05 05:49:56 carjay Exp $
$Id: chkIVersion.cpp,v 1.15 2006/07/30 21:23:29 mogway Exp $
Yadi Release vom 17.03.2007 16:00 - Image-Version 2.2.0.0
Networkcfg eth0: 192.168.0.23/255.255.255.0 gw 192.168.0.1 ns
Startmode: Bootmenu - HWS: on
Please press Enter to activate this console. Avia playback mode set to DualPES
[camd] CA_SEND_MSG: No such device
/bin/enigma: /lib/libpng12.so.0: no version information available (required by /
bin/enigma)
[MOVIEPLAYER] Version 2.1 starting...
enigma, Copyright (C) dbox-Project
enigma comes with ABSOLUTELY NO WARRANTY
This is free software, and you are welcome
to redistribute it under certain conditions.
It is licensed under the GNU General Public License,
Version 2
[eHotplug] created successfully
+ (0) Configuration
reached rl 0
+ (1) Background File Eraser
+ (1) EAUDIO
+ (5) d-Box LCD Hardware
[LCD] set brightness 130, contrast 29
+ (5) eActionMapList
+ (9) GFBDC
812k video mem
+ (9) Font Render Class
[FONT] initializing lib...
[FONT] loading fonts...
[FONT] Intializing font cache, using max. 4MB...
+ (10) gRC
RC thread createted successfully
+ (15) SystemInfo
+ (20) skin subsystem
loading skin: /var/tuxbox/config/enigma/skins/default.esml
loading skin: /share/tuxbox/enigma/skins/default.esml
loading skin: /share/tuxbox/enigma/skins/stone_snr.esml
illegal color "" specified
[FONT] adding font /share/fonts/bluehigh.ttf...OK (Blue.Regular)
[FONT] adding font /share/fonts/bluebold.ttf...OK (Blue.Bold)
[FONT] adding font /share/fonts/pakenham.ttf...OK (lcd)
[FONT] adding font /share/fonts/md_khmurabi_10.ttf...OK (Replacement)
[FONT] adding font /share/fonts/unmrs.pfa...OK (Nimbus)
Font with name lcd already loaded, skip pakenham.ttf
fontalias eStatusBar does exist, skip make alias for font Nimbus
fontalias eChannelInfo does exist, skip make alias for font Nimbus
fontalias eWindow.TitleBar does exist, skip make alias for font Nimbus
fontalias eWindow.Childs does exist, skip make alias for font Nimbus
fontalias eListBox.EntryText.normal does exist, skip make alias for font Nimbus
fontalias eServiceSelector.Entry.Description does exist, skip make alias for fon
t Nimbus
fontalias eServiceSelector.singleColumn.Entry.Name does exist, skip make alias f
or font Nimbus
fontalias eEPGSelector.Entry.Description does exist, skip make alias for font Ni
mbus
fontalias eEPGSelector.Entry.DateTime does exist, skip make alias for font Nimbu
s
fontalias lcd.main.service_name does exist, skip make alias for font Nimbus
fontalias lcd.main.clock does exist, skip make alias for font Nimbus
fontalias lcd.menu.title does exist, skip make alias for font Nimbus
fontalias lcd.menu.element does exist, skip make alias for font Nimbus
fontalias eventview.description does exist, skip make alias for font Nimbus
fontalias eventview.date does exist, skip make alias for font Nimbus
fontalias eventview.time does exist, skip make alias for font Nimbus
fontalias eventview.channel does exist, skip make alias for font Nimbus
Image with name mainmenu.background already loaded, skip mainmenu/background-fs8
.png
image/img="triaxlogo" - /enigma/pictures/triaxlogo-fs8.png: file not found
image/img="shortcut.escape" - /enigma/pictures/shortcut/escape.png: file not fou
nd
+ (25) eTextInputField
+ (25) RC Input layer
sh: cannot open /share/keymaps/eng.kmap: No such file
load keyboard mapping failed
+ (26) Console RC Driver
+ (26) input device driver
Input device "DBOX-2 FP IR" is not a keyboard.
Found 1 input devices!
+ (30) eGauge
+ (30) eSlider
+ (30) eStatusBar
+ (30) eWindow
+ (30) eWidget
+ (30) eProgress
+ (30) eLabel
+ (30) eCheckbox
+ (30) eButton
+ (30) eChannelInfo
+ (35) textedit field actions
+ (35) number actions
+ (35) cursor actions
+ (35) focus actions
+ (35) list actions
+ (35) shortcut actions
+ (35) enigma standby actions
+ (35) TransponderEditWindow Actions
+ (35) enigma helpwindow actions
+ (35) rotor menu actions
+ (35) enigma vcr actions
+ (35) timer view actions
+ (35) timer edit actions
+ (35) tuxtxt offset actions
+ (35) epg selector actions
+ (35) enigma mainmenu actions
+ (35) EPG Style Selector actions
+ (35) service selector actions
+ (35) enigma main actions
+ (35) enigma global actions
+ (35) enigma event view actions
+ (39) stream watchdog
+ (40) eDVB lib
1 lnbs readed
[eAVSwitch] loading scart-config (scart.conf)
[eAVSwitch] readed scart conf : 2 1 0 0 0 0
[eAVSwitch] readed dvb conf : 0 0 0 0 0 0
[eAVSwitch] setInput 0, avsfd=-1
eDVB::eDVB done.
+ (45) eServiceInterface
+ (46) eServiceFileHandler
+ (46) eServiceStructureHandler
+ (47) eServiceHandlerJPG
+ (47) eServicePlaylistHandler
+ (47) eServiceHandlerMP3
+ (47) eServiceHandlerDVB
+ (4 eDVBCAHandler
+ (4 EPG cache
[EPGC] Initialized EPGCache
+ (4 socket mmi handler
[eSocketMMIHandler] created successfully
+ (49) Timer Manager
loading playlist... /var/tuxbox/config/enigma/timer.epl
failed to open.
[eTimerManager] deepstandbywakeup is 0
[eTimerManager] now deepstandbywakeup is 0
FP_IOCTL_CLEAR_WAKEUP_TIMER okay
[eTimerManager] delKey deepstandbywakeup
reached rl 50
[ENIGMA] loading default keymaps...
[eDVB] do nfs/cifs/smbfs mounts
open /dev/dvb/card0/ancillary0 failed(No such file or directory)
lcdMain created: 0x105d9a10
[eZapMain]wasSleeping is 0, wasDeepStandby is 0
no sapi
loading playlist... /hdd/movie/recordings.epl
failed to open.
loading playlist... /var/tuxbox/config/enigma/playlist.epl
failed to open.
loading playlist... /var/tuxbox/config/enigma/userbouquets.tv.epl
loading playlist... /var/tuxbox/config/enigma/userbouquets.file.epl
loading playlist... /var/tuxbox/config/enigma/userbouquets.radio.epl
loading playlist... /var/tuxbox/config/enigma/userbouquet.627cf.tv
loading playlist... /var/tuxbox/config/enigma/userbouquet.a9c85.radio
loading playlist... /var/tuxbox/config/enigma/userbouquet.f2620.file
createService failed!
removeRef on non-existing service!
------------> changed! 0
no transponder 1 44d
[TUNE] tune failed
avia_av: new_audio_config timeout
[ENIGMA_DYN] lockWebIf = 1
[ENIGMA] starting httpd
[NET] httpd server started on port 80
console=ttyS0 detected...disable enigma serial http interface
[ENIGMA_MOUNT] automountMountPoints...
[ENIGMA_MOUNT] automountMountPoints: automount(pid101) - 0
[ENIGMA] ok, beginning mainloop
+ (54) wizard: tv system
+ (55) wizard: language
+ (56) wizard: fpudate
+ (57) wizard: timezone
Dont run Timezone Setup.. timezone is already selected
waitpid: No child processes
+ (5 wizard: scan
reached rl 75
[FONT] creating new font color cache entry ff000000 .. 00ffffff
[FONT] creating new font color cache entry 33294a6b .. 00ffffff
Typenbezeichnung:
Starting kswapd
Not tainted
Call backtrace:
Segmentation fault
. 1).
Detected STB:
Vendor: Sagem
Model: D-BOX2
er](pos. 2).
0.ux'.
bin/enigma)
Version 2
+ (0) Configuration
reached rl 0
+ (1) EAUDIO
+ (9) GFBDC
812k video mem
+ (10) gRC
+ (15) SystemInfo
t Nimbus
or font Nimbus
mbus
s
.png
nd
+ (30) eGauge
+ (30) eSlider
+ (30) eStatusBar
+ (30) eWindow
+ (30) eWidget
+ (30) eProgress
+ (30) eLabel
+ (30) eCheckbox
+ (30) eButton
+ (30) eChannelInfo
+ (35) list actions
+ (40) eDVB lib
1 lnbs readed
eDVB::eDVB done.
+ (4 eDVBCAHandler
+ (4 EPG cache
failed to open.
reached rl 50
no sapi
failed to open.
failed to open.
[TUNE] tune failed
+ (5 wizard: scan
reached rl 75
