Sagt die Log etwas aus???
Also hier mal die Log von Restboot und zappen..
Vielleicht kennt ja jemand den Fehler:
avia_gt_dmx: $Id: avia_gt_dmx.c,v 1.210 2004/06/26 16:08:15 carjay Exp $
avia_gt_core: masking unhandled irq reg 1 bit 11
avia_gt_core: masking unhandled irq reg 1 bit 13
avia_gt_ucode: loaded ucode v001A
avia_gt_ucode: ucode section filters disabled.
avia_gt_dmx: warning, misaligned queue 0 (is 0xFD200, size 65536), aligning...
avia_gt_gv: $Id: avia_gt_gv.c,v 1.39 2004/08/28 16:44:56 carjay Exp $
avia_gt_core: masking unhandled irq reg 0 bit 6
avia_gt_gv: set_input_size (width=720, height=576)
avia_gt_pcm: $Id: avia_gt_pcm.c,v 1.29 2004/01/29 19:38:20 zwen Exp $
avia_gt_pcm_set_rate(44100)
avia_gt_capture: $Id: avia_gt_capture.c,v 1.32 2003/09/30 05:45:35 obi Exp $
avia_gt_pig: $Id: avia_gt_pig.c,v 1.40 2003/09/30 05:45:35 obi Exp $
avia_gt_vbi: $Id: avia_gt_vbi.c,v 1.26 2003/08/01 17:31:22 obi Exp $
avia_gt_core: Loaded AViA eNX/GTX driver
avia_gt_fb: $Id: avia_gt_fb_core.c,v 1.54 2004/03/17 18:42:18 zwen Exp $
avia_gt_gv: set_input_mode (mode=2)
Console: switching to colour frame buffer device 82x32
avia_gt_fb: fb0: AViA eNX/GTX Framebuffer frame buffer device
lcd.o: init lcd driver module
lcd.o: found KS0713/SED153X lcd interface
avia_gt_lirc: $Id: avia_gt_lirc.c,v 1.14 2003/09/30 05:45:35 obi Exp $
avia_gt_ir: $Id: avia_gt_ir.c,v 1.30 2003/09/30 05:45:35 obi Exp $
avia_oss: $Id: avia_gt_oss.c,v 1.26 2004/05/31 22:56:02 carjay Exp $
avia_gt_v4l2: $Id: avia_gt_v4l2.c,v 1.12 2003/09/30 04:54:03 obi Exp $
avia_av_napi.c: $Id: avia_av_napi.c,v 1.33 2004/03/11 15:30:27 derget Exp $
avia_gt_napi: $Id: avia_gt_napi.c,v 1.203 2005/01/05 05:49:56 carjay Exp $
Please press Enter to activate this console. rm: cannot remove `/var/etc/.slot0_
start': No such file or directory
rm: cannot remove `/var/etc/.slot1_start': No such file or directory
rm: cannot remove `/var/etc/.slot_com': No such file or directory
rm: cannot remove `/var/etc/.slot_multi': No such file or directory
rm: cannot remove `/var/etc/.com_betad': No such file or directory
rm: cannot remove `/var/etc/.multi_betad': No such file or directory
[CBasicClient] connect failed.
/tmp/sectionsd.sock: No such file or directory
$Id: zapit.cpp,v 1.395 2007/03/17 21:34:22 houdini, patched by GLJ-Team (JohnDoe
) Exp $
[zapit] PMT update enabled
avia_gt_core: masking unhandled irq reg 0 bit 7
[getservices] /var/tuxbox/config/zapit/myservices.xml found.
[getservices] dup transponder id 1 onid 85
[getservices] dup transponder id 3 onid 85
[getservices] dup transponder id 4 onid 85
[getservices] dup transponder id 11 onid 85
[getservices] dup transponder id 43E onid 1
[getservices] dup transponder id 438 onid 1
[getservices] dup transponder id 442 onid 1
[getservices] dup transponder id 412 onid 1
/tmp/currentservices.xml: No such file or directory
$Id: controld.cpp,v 1.124 2006/06/27 10:21:59 barf Exp $
[controld] Boxtype detected: (1, Nokia D-BOX2)
[controld]: ROUTEVIDEO v1 = 5 a1 = 1 v2 = 1 a2 = 1 v3 = 0 a3 = 1 fblk=1
tuxbox mgcamd v1.26 by mixvt (compiled Dec 2 2007 16:36:55)
[mg] Net:0:7:0:5s Show ecm:1, emm:1 Up:4 Au:2 Dir:0 Osd:no:80:0 Cache:0 Log:2:17
2.16.1.1:28007 Reread:4
[mg] Ecm cache time: 15
Box type: dbox2
Keys readed
[mgcam] emm thread started
[mgcamd] tps update started.
[nhttpd] Neutrino HTTP-Server starting......Patched GLJ-Team (JohnDoe)
[LCDFONT] initializing core...
[LCDFONT] adding font /share/fonts/micron.ttf...OK (Micron/Regular)
[LCDFONT] adding font /share/fonts/micron_bold.ttf...OK (Micron/Bold)
[LCDFONT] adding font /share/fonts/pakenham.ttf...ping:
http://www.google.de: Host name
lookup failure
OK (Pakenham/Regular)
[LCDFONT] Intializing font cache...
$Id: sectionsd.cpp,v 1.237 2007/03/29 15:43:32 mws Exp $
[sectionsd] Caching max 2500 events
[sectionsd] Caching 1 days
[sectionsd] Events are old 60min after their end time
/var/tuxbox/config/zapit/epgfilter.xml: No such file or directory
/var/tuxbox/config/mybouquets.xml: No such file or directory
[basicsocket] send_data: Resource temporarily unavailable
/tmp/neutrino: /lib/libpng12.so.0: no version information available (required by
/tmp/neutrin
[neutrino] frameBuffer Instance created
812k video mem
[neutrino] Software update enabled
[neutrino] enable flash
[deutsch.locale] superfluous entry: flashupdate.currentdistribution
[lcdd] time-skin not found -> using default...
[lcdd] weekday-skin not found -> using default...
[lcdd] date-skin not found -> using default...
[lcdd] month-skin not found -> using default...
[LCDFONT] adding font /share/fonts/12.pcf.gz...OK (Fix12/Regular)
[LCDFONT] adding font /share/fonts/14B.pcf.gz...OK (Fix14/Bold)
[LCDFONT] adding font /share/fonts/15B.pcf.gz...OK (Fix15/Bold)
[LCDFONT] FTC_Face_Requester (Fix15/Bold)
[LCDFONT] FTC_Face_Requester (Fix14/Bold)
/dev/input/event1: No such file or directory
[neutrino] menue setup
loading locales: scandir: No such file or directory
[neutrino] received 18 sats
[neutrino] registering as event client
[neutrino] initialized everything
[timeThread] - 29.12.2007 16:42:17, tim: Sat Dec 29 16:42:17 2007
SPTS, queue 0 extended.
got 30 cmd 9F
avia_gt_core: masking unhandled irq reg 1 bit 15
CA_SET_PID error 22: Invalid argument
[mg0] service 6DCA index 0 pmt pid 0 (1)
/tmp/camd.sock01: No such file or directory
/tmp/camd.sock02: No such file or directory
[timeThread] Time set via DVB, going to sleep for 1800 seconds.
[mg0] No supported encryption system found
[mg0] stopped
/tmp/camd.sock03: No such file or directory
/tmp/camd.sock04: No such file or directory
[controld] VIDEO_EVENT_SIZE_CHANGED 720x576 (4:3 -> 16:9)
/tmp/camd.sock05: No such file or directory
[mg0] stoping camd..
got 61 cmd 9F
[mg0] service C index 0 pmt pid 0 (2)
ECM: CaID: 0x1801 -> CaPID: 0x169E ProvID: 000000
ECM: CaID: 0x1830 -> CaPID: 0x199E ProvID: 000000
ECM: CaID: 0x0D05 -> CaPID: 0x1F9E ProvID: 000000
got 30 cmd 9F
[mg1] service 6DCA index 1 pmt pid 0 (3)
[mg1] No supported encryption system found
[mg1] stopped
got 20 cmd 9F
[mg0] service 701 index 0 pmt pid 0 (4)
[mg1] stoping camd..
[mg0] stopped
[dmx.cpp:read] read(fd, buf, n): Connection timed out
zap failed!
[LCDFONT] FTC_Face_Requester (Fix12/Regular)
got 25 cmd 9F
[mg0] service 445C index 0 pmt pid 0 (5)
[mg0] stopped
avia_av_wdt_thread: video decoding stopped ==> restart
got 20 cmd 9F
[mg1] service 2F08 index 1 pmt pid 0 (6)
[mg1] stopped
[controld] VIDEO_EVENT_SIZE_CHANGED 720x576 (16:9 -> 4:3)
got 20 cmd 9F
[mg0] service 445E index 0 pmt pid 0 (7)
[mg0] stopped
got 20 cmd 9F
[mg1] stopped
got 20 cmd 9F
[mg0] service 2EF4 index 0 pmt pid 0 (9)
[mg0] stopped
