eduardsik
- 15.08.2023
- 1
- Hersteller
- Miele
- Typenbezeichnung
- G6360SCVi
- Kurze Fehlerbeschreibung
- Slide Shutter Fault, motor not having control signal
- Meine Messgeräte
- Analog/Digital Voltmeter
- Oszilloskop
- Schaltbild vorhanden?
- Nein
Hello community!
I bought a Miele G6360SCVi diswasher and found the slide shutter not working and the dishwasher not washing properly. I measured the connector on the slide shutter and not receiving the 230V, just 50V AC. When I disassembled the control panel, on the ST14 connector (related to the syncron motor and the microswitch) I found very light gray burn marks. The connector inside is clear and on the PCB no burnmarks at all. But I found a damaged IC ASC1026T (a triac) which is at some distance from the ST14 connector, so I think is not related to this fault, but very interesting, because the dishwasher is working properly, just the slide shutter not as I figured out.
The control panel has a type of ELPW 5662-K
- what controls the synchronous motor signal, what component do I check?
- What is the purpose of the defective IC?
Thanks in advance!
Eduard
Thanks in advance!
Eduard
